Showing results for tags 'shp files'.
I am using AutoCAD Map 3D 2010. I have inserted my shp files of my points and a basemap that I use for ArcGIS. I can draw a polyline to connect my points and the polyline is visible and I save my map and close it down. But when I open the map again the polyline is not visible, selectable or anything...
Custom Linetype not plotting correctly when publishing DSD
numberOCD posted a topic in AutoCAD Drawing Management & Output
Hey everyone, Our office is publishing large PDFs for submittals from DSD files and we are hitting a snag where one custom linetype I wrote 5 years ago that referenced a shp file is working 50/50. Half of our DSDs are publishing 100%, then the latter half are not loading the linetype. Also, if... -
I have received one (1) large SHP file that has all of the individual municipal/village boundaries for a larger city. I guess the same question would apply to isolating certain rivers or streams from a SHP file that contains all in the state. Is there any way I can extract or change these shape are...
