Showing results for tags 'sheetset manager'.
    • sheetset manager ×
Found 6 results
  1. I've discovered the joys of sheet set manager. I recently found out that I can make a table of contents using it that will update as I add sheets. However, with larger plan sets I would like to list the sheet type and a page range (see example) instead of listing every sheet in the sub set. Is this...
  2. I've updated the company templates to work with sheet sets. I've tried on another PC in the office and the same thing happens. This happens most of the time when I cannot edit the details of the sheet set, rename or import layouts. We are connected to a server and our speed i...
  3. I've been searching for an answer to this question: What if any is the advantage of placing fields in Block attributes Verses placing the fields in Mtext for the same purpose( think title bock info and numbering)? My initial thought is that it's just two ways to skin the same cat. HOWEVE...
  4. The problem we are having is drawings "automatically" switching to Read-Only when other users open the same drawing using the Sheet Set Manager. We've been using the Sheet Set Manager, in the same way, with the same amount of users, for years. The problem has only occurred recently. Here's th...
  5. Hello, My name is Ben and I am currently working in an architectural/engineering firm. I have recently learned about Sheetset Manager and I was able to input my custom sheetset. What I am trying to do is create a custom sheetset template that will have ALL my sheets embedded, that way all m...
  6. I'm in the process of moving 100+ dwg files physically, but cannot figure out how to update the drawing locations w/o recreating a Pre-Existing fully populated (names, drawing numbers, etc.) SheetSet. Here's what I want to do: Move dwg files from one location to another & update the new physica...
