Showing results for tags 'sheet sets'.
    • sheet sets ×
Found 12 results
  1. We have a client that put their drawings (titleblocks and linework etc) in model space rather than paper space (layouts). Is it possible to link model space titleblocks to sheet sets, instead of layouts? I'm using AutoCAD 2017
  2. I have a very specific question regarding sheet sets, specifically the sheet list table that I am hoping someone 'advanced' in sheet sets can answer for me. What I am having an issue with is for my sheet set templates to 'remember' which extra fielded attributes I want to have included automatic...
  3. Good day kind souls of cadtutor. i have been googling this problem for days but it seems that i am the only one experiencing this kind of misfortune with sheet sets. This actually is the reason that i registered here in cadtutor and get some help. The sheet set manager is an awesome tool (i just...
  4. Hey friends...first post here but I've been lurking and taking advice from you all for a while. I'm rebuilding the primary project template folder for my company. This folder contains a variety of drawings linked together using Xrefs and such. I'm setting up sheet sets to help in the plotting of...
  5. Hi All, Need some help! My problem is this; I have several production sets (Sheet Sheets) of drawings in which the referenced drawing's layers are not carrying over. To clarify; In my base file file I went through and froze out and changed the color of several layers. When I reference that...
  6. I've created a Sheet Set and added custom properties for things such as Drawn By, Checked By and such. Whenever I link my title block to these fields, the value shows up but when I change the value in the Sheet Set properties, the value is not automatically updated. I have to manually redirect it to...
  7. We have 2 machines running Windows 7 64bit, and AutoCAD 2012. We use sheet sets extensively. When inserting a "sheet list table", which we use as our drawing index, it takes anywhere from 5-20 minutes on our Win7 machines, but takes only 2-3 seconds on our WinXP machines. Has anyone else run in...
  8. Greetings, I am trying to figure out how to program the following: 1. Invoke a command that will first ask the user to select the location of the source drawing. For example (setq TblockSourceFile (getfiled "Select Title Block Source Drawing" "p:/" "dwg" 4)) 2. Programmatically "harvest" the attr...
  9. Hello! I'm trying to find an intelligent way to reorganize the custom properties in my sheet set. Some are poorly named, others I suspect aren't even used. As far as I can tell, you can't rename a custom property; you have to create a new one, transfer the definitions throughout the sheet set...
  10. I'm thinking about using sheet sets to manage projects better and so I can use fields in my title block. I want to use the sheet set manager to add sheets to my plans but every time I create a new sheet it creates a new .dwg file. Is possble to just create a new layout in the current drawing?
  11. Hey Guys I have an interesting one that has got me stumped. My team all uses sheet sets and we are constantly plotting using the page setup overrides. We are currently wasting a lot of paper because the landscape setting in overrides dwt's page setup keeps reverting back to portrait and...
  12. Does anyone know if it is possible to use LISP, or VBA, or any sort of macros to add, or change custom properties within sheet sets?
