Showing results for tags 'sheet set manager'.
This is more of a solution than a problem, in case it happens to someone else. tl;dr: When you publish a sheet set, you may get an unexpected alignment in your output. I have a drawing created with LDD. I wanted to add a sewer profile, so I created an alignment. The alignment object was...
- sheet set manager
We have a client that put their drawings (titleblocks and linework etc) in model space rather than paper space (layouts). Is it possible to link model space titleblocks to sheet sets, instead of layouts? I'm using AutoCAD 2017
- 4 replies
- sheet set manager
- sheet sets
Sheet Set not auto loading in sheet set manger when opening drawing.
Tudors posted a topic in AutoCAD Drawing Management & Output
I have a few drawings that will not load dst. file in sheet set manager? If i want to edit i have to manually open in sheet set manger. I have other drawings working fine. SSMAUTOOPEN and SSLOCATE variables are already set to 1 How to I associate sheet set to drawing and have it auto lo... -
Sheet Views not showing in Sheet Set Manager
Frenzy808 posted a topic in AutoCAD Drawing Management & Output
AutoCAD 2015 I have created a sheet view on my DWG so I can place a callout block on another DWG. The problem is this new sheet view I created on my DWG is not showing in my Sheet Set Manager list for the project I'm working with. Anyone experienced this if so is there a way to correct this...-
- sheet set manager
- not visible
Sheet Set: Insert Sheet List Table Content Format/Template Issue
Cadologist posted a topic in AutoCAD Drawing Management & Output
I have a very specific question regarding sheet sets, specifically the sheet list table that I am hoping someone 'advanced' in sheet sets can answer for me. What I am having an issue with is for my sheet set templates to 'remember' which extra fielded attributes I want to have included automatic...- 9 replies
- sheet set template
- sheet set manager
Sheet Set Manager not showing drawings in folders
kolcinx posted a topic in AutoCAD Drawing Management & Output
Hi there. Problem : I`m trying to create a sheet set from existing drawing. When I browse to the folder where the drawing is, it doesn`t show me it in "Choose Layouts" window. I tried renaming the drawing, putting it in another folder, deleting all *.dst files but no success. Few days ago, it w... -
Sheet Set Manager - Publish to PDF - Print slightly off
duccioa posted a topic in AutoCAD Drawing Management & Output
Hello, I'm using Autocad LT2012 and I have a problem with the "print to PDF" from the Sheet Set Manager. The layouts are all set to "publish to a plotter" with the Layout option (not Window, Extent, etc.). When I send the print to the plotter from the SSM, they print fine. If I send them to PDF,...- 4 replies
- publishing issues
- print problem
Right click to change scale is kind of moody when placing views on sheet
michaeltadeo posted a topic in AutoCAD Drawing Management & Output
Good day kind souls of cadtutor. i have been googling this problem for days but it seems that i am the only one experiencing this kind of misfortune with sheet sets. This actually is the reason that i registered here in cadtutor and get some help. The sheet set manager is an awesome tool (i just... -
I am using the Sheet Set manager to just publish my drawings to the named plotter (Adobe PDF). I an NOT using any fields. I do not have any sheet numbers assigned in the sheet set. Each drawing is a separate file with only one layout tab in each file. On each drawing, the sheet title and drawing num...
- 4 replies
- sheet set manager
- sheet set
Hello, I'm using Sheet Set Manager in Autocad 2011. I'm using 'page setup override', and as plot area 'print extents'. So far, so good. Until someone forgets something outside the title block, and the extents feature is not good anymore (several people working in the same projects). So, I...
- sheet set manager
I've created a Sheet Set and added custom properties for things such as Drawn By, Checked By and such. Whenever I link my title block to these fields, the value shows up but when I change the value in the Sheet Set properties, the value is not automatically updated. I have to manually redirect it to...
- 13 replies
- sheet set manager
Good morning everyone. I hope someone can send me in the right direction. I've been using sheet set manager for awhile and I honestly don't know how I worked without it in the past. My issue is this: On my server, I have a Project folder. The name of the project folder is our drawing number...
MText, Sheet Set Manager, Fields & Blocks
baker posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
I have a block that has MText in it. I need it to refrence the sheet set manager "CurrentSheetTitle" sometimes the title can be long, so i am using mtext so it will wrap correctly. when i insert the block other attribut fields display properly, but the mtext for this field does not. after i expl... -
Publish not working in sheet set manager
Ace posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hi all I have this reoccurring issue with ACAD. It appears randomly and whenever we upgrade to newer versions of ACAD also. Now that we are upgrading to 2012 it has reared its ugly head again. Heres the issue; when I go to publish a set of drawings from sheet set manager it refuses to do so. It... -
I'm thinking about using sheet sets to manage projects better and so I can use fields in my title block. I want to use the sheet set manager to add sheets to my plans but every time I create a new sheet it creates a new .dwg file. Is possble to just create a new layout in the current drawing?
- 3 replies
- sheet set manager
- autocad 2006
Is there a way to sort sheets in SSM alphabetically?
