Showing results for tags 'sheet set'.
    • sheet set ×
Found 8 results
  1. Using Autocad Arch. 2014 I am new to sheet sets so here is what I want to be able to do. My architectural drawings has a line for Issue Date. I want to be able to change the Issue Date only once and have all of the sheets "Issue Dates" updated. What I am currently having to do is to change the dates...
  2. We have a client that put their drawings (titleblocks and linework etc) in model space rather than paper space (layouts). Is it possible to link model space titleblocks to sheet sets, instead of layouts? I'm using AutoCAD 2017
  3. I have a few drawings that will not load dst. file in sheet set manager? If i want to edit i have to manually open in sheet set manger. I have other drawings working fine. SSMAUTOOPEN and SSLOCATE variables are already set to 1 How to I associate sheet set to drawing and have it auto lo...
  4. Hello all, Is there a way that I could use a lisp to update text inside the Sheet Properties of a sheet set? I am asking because I am currently trying to figure out the best way to implement SSM with my company but there just seems to be problem after problem. the most current problem is any...
  5. I am using the Sheet Set manager to just publish my drawings to the named plotter (Adobe PDF). I an NOT using any fields. I do not have any sheet numbers assigned in the sheet set. Each drawing is a separate file with only one layout tab in each file. On each drawing, the sheet title and drawing num...
  6. Hey guys, I have an interesting predicament. I have a ton of sub-sets within a sheet set and I would like to print each sub-set as a multi-page pdf. My LISP is decent, but I have no idea how to interface in this manner with the SS. Does anyone have any tricks? Or, can someone point me in the right...
  7. I am working a lot with layers and since i am also working with sheet sets, it would be very nice to be able to freeze/unfreeze layers for the whole sheet set. Right now i need to freeze/unfreeze layers separately for each page which takes me a quite long time. Anyone have a solution to this? Th...
  8. Fellow Cadders, I've encountered a pretty nasty problem over the past week. I can no longer add specific layouts to existing sheet sets. I can make a new sheet set, but I cannot see the drawings that I would like to add to the sheet set. The only "solution" I've found is to make a new sheet...
