Showing results for tags 'shape file'.
    • shape file ×
Found 4 results
  1. CADMAN57
    New line type and font
    Good morning... I'm creating a set of new utility line types for our surveying department. Water lines, sewer, and so forth. They will all have a "W" or "SS" in them, depicting the type of line. I want them to look differently from our civil department's lines, so I am trying to make them with a...
  2. Hello all, I'm looking for some way to convert ESRI ArcGIS geodatabases and/or shapefiles into CAD linework using vanilla AutoCAD. In my office (petroleum industry), we use utility data, parcel and ROW data, and topo data (especially contour lines) the most, so these categories are the stuff w...
  3. I am using AutoCAD Civil 3D 2011. I am trying to import a shape file (contours) into a drawing that was given to me by a client. So I went into the Tool-Based Geospatial workspace, went insert>map import>selected my shape file and clicked ok. It inserted, but its in the wrong spot. I'm assum...
  4. Hi, im working on a project for university and it involves using .shp files, which i've imported fine, however the problem is that when i draw a line or polyline then save the file, close the program, reopen the file, the polyline appears for a split second while opening but then it disappears once...
