Showing results for tags 'shade plot'.
Viewport shade plot always resets to "as displayed" when saving.
dstonge posted a topic in AutoCAD Drawing Management & Output
I've set a viewport's shade plot to "legacy hidden" but after I save it automatically returns to "as displayed". The VP shade plot settings will not hold. Funny thing is... If i flip to the MS tab and save, then back to the PS tab, the VP shade plots are retained at "legacy hidden". But anytime...-
- shade plot
- hidden
When i try and plot my 3D model in the Hidden style, so it simply looks like a black line drawing the plot comes out weird. The plot for some reason adds a thick black line around my entire plot, and makes all the other lightweights look faded out. How can i fix this??primary bar 3-Layout2.pdf
- 1 reply
- plot
- hidden lines
In desperate need of help! Is there a 'special' set up for plotting in MEP? What I want to do is have shadeplot "hidden" on my viewport but keep the duct centrelines. We don't want to send our client 2D wireframe type drawings AND we don't want to have to manually re-do the centrelines.
I am having some difficulties when printing via dwg to pdf a rendered shade plot viewport in a layout. However, there is no problem using realistic shade plot. I am using the following materials: Metal | Alumininum (Anodized Blue, Anodized Blue-Gray), Plastic and Glass and the result is not goo...
Hidden Lines won't stay hidden when plotting
jonesy4000 posted a topic in AutoCAD Drawing Management & Output
I've read several threads about having problems with lines that are supposed to be hidden or obscured continuing to show up in paper space and plotting, but none of them have been able to help. Here's the situation: I'm drawing objects (walls, platforms, etc.) in 3d made up primarily of extrude...-
- hidden lines
- extruded polygons
