Showing results for tags 'set same height'.
    • set same height ×
  1. Hi Inventor passionists, I would like to use constrains on axis(es), plane(s). For example using coincident button for a line to X axis (to sit the line on that axis). (Or dimension 0mm alternatively.) But,... the constrain does not recognize axis(es) and plane(s), even I make it/them visible....
