Showing results for tags 'set distance'.
  1. Hello, First of all, happy new year. Every time I have some new object to dimension i come up with this issue: I create dim lines to measure the sides by clicking point 1 to point 2 and then point 3 to define the offset of the dim line in regards to the object. The issue is that i want my dim lines to be equally offsetted from the object, and therefore i have to draw up the dim lines, then a circle with 'x' radius that I move around to manually adjust each of the dim lines to the desired offset distance position. Maybe be a silly way, but I've ran a check online for 2 or 3 times trying to find out an easier way to do this but I had no luck. Does anyone know a lisp that could set up the desired offset distance of the dim line for selected dimensions? Select dim lines > specify offset distance from object... I'm wasting too much time with this part of the job, and if anyone could help by pointing me the right way, I would be more than appreciated. Thx for your time Best regards, Nuno
