Showing results for tags 'set current'.
    • set current ×
  1. I have a routine that I've been using but I would like to modify it just a bit. The function is for creating Deed Sketches that allows the user to create a new layer and select a color. It works great but if you happen to exit the command, and need to start again, it still asks for a new layer. I wo...
