Showing results for tags 'selection sets'.
    • selection sets ×
  1. Hi, I am trying something like this: (setq ed (entget (car (entsel)))) (setq lyr (cdr (assoc 8 ed))) (setq clr (cdr (assoc 62 ed))) How can I get a selection set based on layer and color of a given object? Something like: (setq objs (ssget "X" '((cons 8 lyr) (cons 62 clr)) ) ) [i k...
  2. Hi Sirs, I'm just new on using autolisp and still learning so please help me on the dilemma i'm facing. Basically i want to sort a selection set of polyline (rectangle) under the layer of "REF" basing on it's X axis. I copied bits of info around the net but i can't get it work the way i want...
  3. I am writing a routine that requires that I remove objects from a selection set while still keeping the original set around. After running into issues, I created a test routine to see how ssdel is operating. I want it to remove selB from selC, while keeping selA and selD untouched to hold the origin...
