Showing results for tags 'selecting text'.
Has anyone had this problem with selecting text? I use AutoCAD 2005, and I've made project logs which contain mtext for logging work I do each day, and tables for logging Revisions and prints and whatnot related to the project. I've noticed, especially since adding the tables to the log template, th...
Insert Blocks at Insertion Points of Selected Characters
nick777 posted a topic in AutoLISP, Visual LISP & DCL
Right now I have 15,000 drawings that use letters instead of symbols, an artifact of a now defunct CAD software that translated the letters into symbols. I'd like to remake this in AutoCAD by inserting blocks at the location of those letters. I cannot find instructions on how to do this anywher...- 6 replies
- block library
- block insert
Hi all, I have a lisp routine that i wrote that when i run it, it will wblock out what i need to a separate file just by clicking on the border of the object, it uses the (Useri1) variable to asign the file name which is okay but i would like to be able to click on the part number (B2) for examp...
Hi All, I'm looking for a routine that when i select the text it would create a layer with the text as it's name. i.e text (S7) = layer name is S7. thanks Brian
