Showing results for tags 'selecting items'.
    • selecting items ×
Found 4 results
  1. I have the Ctrl+Q set up to select similar. Quite handy when used with another shortcut I've set up Ctrl+H to hide that selection or any other command I wish to invoke after. This works great but I was hoping to know if it's possible for the same standard command of AutoCADs select similar can b...
  2. Hello all, real newbie here.. My first question is: AutoCad 2016 (student ver.) is there a possible way of selecting one line (property RED) and then have a command that could select all the lines in model space that have the color RED?? Could it be done with using any of: linetype/lineweight/...
  3. I have been looking for a lisp routine to select 3 dimensions and 3 text items and put them back into the dwg in a row. I'm working in paper space so I have to pick the dimension text not the entity. Any help would be great. I just need a basic start in the correct direction. Thanks
  4. Hi everyone, I have a quick question. I have to ad a object to the legend of a map in autocad. The map contains a grid with on the right lower corner a legend window. Someone else drew some tents and fences on the map and most of the object were copied and placed in the legend with the...
