Showing results for tags 'select objects'.
Lisp Request - Select object in paperspace in across multiple layouts
eyeofnewt555 posted a topic in AutoLISP, Visual LISP & DCL
If only QSelect weren't lying when it gives the option to search "Entire Drawing." As the title says, I'd like to be able to grab all instances of an object (typically a block) across multiple layout tabs in paper space (if it were in model, this wouldn't be a problem). The end goal being to cha...- 21 replies
- layout tabs
- paperspace
Hello Everybody, this is my first post and I'd like to know a little bit more about the ssget command. I already searched the world wide web for various search keywords, but couldn't find references / lists, especially of the Associative codes and object types. I also read a lot of articles...
- 24 replies
- ssget
- select objects
