Showing results for tags 'select object'.
    • select object ×
  1. Hello Everybody, this is my first post and I'd like to know a little bit more about the ssget command. I already searched the world wide web for various search keywords, but couldn't find references / lists, especially of the Associative codes and object types. I also read a lot of articles...
  2. this might be simple to fix, when i selected object drag from top left to lower right, before it usually select as rectangle but now it shows something like LASSO, how do i fix this? i just want regular polygon select window. can i turn it off somewhere so it stops doing this. Thanks
