Showing results for tags 'select area'.
    • select area ×
  1. I have an extrusion problem. Hover the cursor over Sketch 6 in the IPT file. My plan was to extrude (cut) areas A & B 25mm into the part. Problem is that I cannot select these areas by themselves. Why not and how can I fix this? Thanks _Extrude_Selection_Problem.ipt
