Showing results for tags 'select all'.
Create slope with lisp Polyline (WANT TO ENHANCE)
Prageeth posted a topic in AutoLISP, Visual LISP & DCL
I Have lisp for placing slope and arrow with polyline and i want enhance this to what i need mention in my drawing file..so i have attached lisp & sample drawing file . and also want to enhance lisp for select all polyline at once, currently lisp select on object at once. thanks....- 3 replies
- slope lines
- slope
- (and 13 more)
select multiple polylines and convert straight to arc segments
jntm226 posted a topic in AutoLISP, Visual LISP & DCL
this lisp convert polyline segments to arcs . work one line for time . i need select 1000 polylines for times. I'm new in autolisp and i do know what change in the code : (defun c:lwsegs2arced ( / massoclst nthmassocsubst v^v unit _ilp doc lw enx gr enxb p1 p2 p3 b i n ) (vl-load-com) (def... -
Hi, I'm searching a lisp that selecting layers by them name. As an example I give some names: AAA_BBB_xxx AAA_BBB_xxy AAA_BBB_xyz I need to select all layers that names start as AAA_BBB. The third part of name is changing. In this case I'd like to select only this layers that name has...
Hi all, I'm trying to set up a button in my ribbon for a simple process I very regularly perform in AutoCAD 2010 LT. basically I want to: 1. Select everything in the model view (through an already active viewport) 2. Erase it all 3. Purge everything 4. Paste in whatever is in the clip...
