Showing results for tags 'script file'.
    • script file ×
  1. Hi, I am have a database containing object information. I am able to write out a script from my database that inserts blocks into Autocad C3D. Here is an example of the script file: osmode 0 -layer Set "2020_DESIGN" ATTREQ 1 ATTDIA 0 -insert "DESIGN" 607476.547,7574318.945,0 1 1 0...
  2. Baber62
    Script file
    Need to create a script file that will run lisp routine below, needs to open *.dwg files in folder one at a time then run the lisp routine, save file, then close file and then open next file in directory. Any assistance greatly appreciated. ; (purge-unreferenced-images) (defun purge-unrefere...
