Showing results for tags 'script command lisp'.
    • script command lisp ×
  1. Greetings, Im working on a test lisp to see if I can automate binding an existing xref & converting a bounded block reference back into an xref. while I was able to automate bind, I realized the express tool (-blocktoxref) is incompatible with lisp as it cant seem to find the command. Then I cre...
  2. Hi, dear experts. I'm creating multiple drawings and they all have a bunch of TEXT entities at the same Y coordinate, it could be 1 or it could be more. In order to enclose all of those TEXT entities in each drawing, I normally do this: right click in every drawing quick selection...
