I have just had to reinstall LT 2014 after a Windows reinstallation.
I have AutoCAD up and running and transferred my user setting OK.
The problem I have is I can no longer see the SCALE properties of dashed lines or hatch patterns in properties dialog box. I also no longer see an option to set the orientation of a hatch pattern either?
Once I installed 2014, I was prompted to install the update, which I did "I remember doing this in the past also"
Is there an option that just needs "turned on" or is the problem elsewhere?
Along with the above problem is another similar. When I right click "Quick Properties" the small box displays, but it has no content inside it at all. Everything is blank. And clicking on a small drop down box causes a crash every time.
Any help appreciated.
Gary.
