Showing results for tags 'scale list'.
    • scale list ×
Found 4 results
  1. Hi, I recently added some custom scales to my scale list and these now appear when I use the reset function during the SCALELISTEDIT command. Great! However, I have since created some more custom scales yet these do not appear when resetting the list How do I add new custom scales to the li...
  2. Born and raised in the States, and having worked for decades as a carpenter, I am quite familiar with the Imperial system of measurement. I remember hearing in elementary school in the fifties that we would soon be switching to Metric, yeah right. After almost 20 years living on the other side of...
  3. If I used millimeters as my UNITS, how can I scale them when plotting it into A1 or A0? How will I know the scale that I will use in Layout tab so that it will fit on the paper that I will used?a
  4. Hi Guys, I am writing a program for adding scale lists in AutoCAD 2010. This is where I am; (defun AddMetersScales() (command "-SCALELISTEDIT" "ADD" "1:5000 (Meters)" "0.2:1" "Exit") (command "-SCALELISTEDIT" "ADD" "1:3000 (Meters)" "0.3333:1" "EXIT") (command "-SCALELISTEDIT" "ADD" "1:20...
