Showing results for tags 'scale issues'.
I have 2010 and for some reason today cannot alter the scale of my drawings...model space is set for 1:1, paper space displays viewports at 1/8", but once I shift to 1/4" most lines [not just annotative objects/text] disappear, however are still there because I can still highlight them...same thing...
- 2 replies
- scale issues
- dissapearing lines
Trying to practice annotative scaling in viewports, but dimensions in the lower right viewport are larger text than they should be. Is something compounded to make it larger? All are using same annotative dimension style. I feel like it's something obvious thank you! [ATTACH]54698[/ATT...
- 18 replies
- scale issues
- dimensions
Dimensions not matching line size. I draw a line at 250', dimensions say 250". Cannot attach file because it is too large. Drawing is located in Dropbox link below. https://www.dropbox.com/s/98mi753t7u3ihd8/Gulfport.dwg?dl=0
