Showing results for tags 'scale factor'.
Print CAD Drawing according to desire scale?
tipu_sultane posted a topic in AutoCAD Drawing Management & Output
I just want to print a CAD drawing according to some required scale. Please help me I have never done this before. I needs some hint. 1:1 1:2 1:3 1:4 1:5 1:10 1:100 Another thing what if I convert the drawing having specific scale into PDF format and print it. Are the scale remai...- 16 replies
lsp help for finding the scale factor of two selected objects! example: circle
jamesfui posted a topic in AutoLISP, Visual LISP & DCL
hi.. need help on creating lsp that can: > find the scale factors on two selected objects & insert to dwg as dtext! example; ``````` select the two objects with different sizes; circle_1: diameter = 1500 circle_2: diameter = 1200 calculated scale factor for [circle_1/circle_2] = [1... -
Dimension Text Height too Small
caitiebe posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
I am trying to dimension a 1/8" drawing (in model space) and the text height on the dimensions is so small it is not even readable. I have tried modifying the dimstyle to have an "Overall Scale" of 96 (under 'Fit') and a "Scale Factor" of 1 (under 'Primary Units') and vice versa, but neither is work...- 11 replies
- scale factor
- dimensions
