Showing results for tags 'scale dim'.
    • scale dim ×
  1. Okay, I'm new to drawing and I need help getting my text/dimensions to be legible on an 11x17 sheet. I had no problems when my company used Arch D (24x36) but in an effort to "going green" we converted to the B size paper (11x17). Has anyone found a useful chart for plotting in different scales....
  2. Psylent
    Dimensions Size
    Hi, I am using AutoCad 2010 Lt. When dimensioning parts the size of the dimension is very very small, i change the dimension style to Annotation and change the Annotation scale down the bottom right hand side then click linear dimension and it hasn't changed the size ? Sometimes it seems t...
