Showing results for tags 'scale block'.
    • scale block ×
Found 5 results
  1. Hi, Good day to you all.I'm new to this forum. I hope you people can help me out. I'm working on, automatic creation of title block with required scale setting in 'Model space' not in layout. by clicking a button or comment, it should ask the user to select the 'title blocks' among the list,...
  2. Hi all, Ok, so I am a newbie here (and to AutoCAD). I did attend a beginners 4-day course a few months ago (before I got CAD in work) and I've forgotten half of it. I started on a new template - changed 'units' to architectural as this project needs to be measured in feet & inches. I started...
  3. I am trying to convert a drawing from mm to inches which should be totally simple. Everytime I scale it in the drawing it becomes completely unreadable and looks insane. When I block the entire drawing and try to insert it into a new drawing set in inches it is huge and I cant pan or see anything ex...
  4. I am trying to scale a drawing to make it a 10 to 1 scale for X to Y. I have read people's posts about making it a block then changing the scale, but I am lost. I have made the object a block but can't find out how to change the scale or explode the block again. Any help is great!
  5. Back ground: My blocks are comming in at the wrong size. I read a post some time back that had the setvar as a side note tidbit that talked about it. I wrote it on a stick note but the dang thing fell behind my 300 lb desk. I have done a search for it but, can't remember what I was looking for when...
