Showing results for tags 'save as'.
    • save as ×
Found 8 results
  1. Hi All, I was wondering if there was a way to save a copy of my drawing into two different locations when i hit a button..ie flash drive hooked to my computer and my sever at the same time? Thanks, Brian
  2. Hi, I would like to know if I can change default folder AutoCAD opens when I create a new drawing, and click "Save As". Thanks, Luis.
  3. Hi all, Some how the variable for saving the dwg file has changed. So, when I save a dwg, I get the prompt for me to type in the file name. Anyone know by chance what the setting is to change it back? Many thanks
  4. Hi guys, my knowalge of scripts is 0 is it posiable to have script always running when the user do a save as and check in a excel if the file name exist. Thanks
  5. hello something's changed in my autocad 2012 setup and I'm being asked to provide full written addesses within the system for files I want to "save as" under a different name, or insert as raster images for example. the moment I click on "save as" an on screen request pops up, like the one you s...
  6. JURRASIC
    Dialog Box Missing
    I was on my previous employers computer with auttocad (he says)2009 (it says 2007). I was helping him make a few tweaks. In short I made his SAVEAS dialog box dissapear. Now when hitting "saveas" it shows in the comand line- no popup dialog box. Please help me fix this error (and get me out of hot w...
  7. RickyS
    Save As in Windows 7
    I recently upgraded to windows 7 and AutoCAD 2012, when I hit save as the cursor or highlighted field is in the directory area not the file name. When I'm detailing I use save as a lot and this little quirk causes me about three extra steps, and kills my rhythm. Our XP machines defaulted to the fi...
  8. mr cadman guiff
    Saving files - AutoCAD 2011
    I'm using AutoCAD 2011. When I click on 'File' and then 'Save As', instead of a dialogue box on screen, I get, on the command line, the following: 'Enter File Format R14 (LT98 & LT97/2000/...........up to 2010) How can I get rid of this of the command line and get the dialogue box back? Thanks...
