Showing results for tags 'save a copy'.
Hi All, I was wondering if there was a way to save a copy of my drawing into two different locations when i hit a button..ie flash drive hooked to my computer and my sever at the same time? Thanks, Brian
Save A Copy As AutoCAD .dwg - preserving arc properties
ndogg1080 posted a topic in Autodesk Inventor
Hello, I have Inventor 2008 SP2 and AutoCad 2008 running on a Windows 7 machine. Since it has been installed on this machine, I am having trouble saving an Inventor 2D drawing as an ACAD 2D drawing. The drawing translates OK except that the radii in the Inventor Drawing turn into many small line... -
Saving part "as copy" that uses an Excel spreadsheet (Inventor)
JR_Ohio posted a topic in AutoCAD Beginners' Area
I created a spreadsheet of about 40 rows to be used to create different parts. I then created a part "we'll call it Board_A". I linked to the spreadsheet and used 3 of the fields for my dimensions. Lets say I named the length (which was the extrusion number) as "Len_1". I saved it and all is wel... -
lsp help for saving a copy of all opened dwgs to specified folder with suffix no.++!
jamesfui posted a topic in AutoLISP, Visual LISP & DCL
hi.. need help on creating lsp that can: > save out a copy each on all opened dwgs to specified folder with suffix increase as per existing by next number! example; ``````` Currently opened dwgs: abc.dwg , def.dwg , ghi.dwg , etc.dwg when the command function is execute, it will creat...- 3 replies
- save a copy
- opened dwgs
