Showing results for tags 'rotated ucs'.
Perhaps someone here has seen something similar. Using 2011 mechanical, I have rotated my ucs about the x-axis 90deg. I then draw a circle with a line thru it. I can trim the line to the circle but I cannot trim the circle to the line. I have verified the objects are co-planer and, in fact, do intersect. I have repeated the same process using 2009 mechanical on this machine and it works fine. I have tried the same process on a co-workers machine running 2011 mechanical and again it works fine. I have created a new drawing and copied all of my geometry into the new file...no joy. I have also ran the "repair install" from the control panel and again no change. Any ideas?
- 4 replies
- circle
- rotated ucs
Text rotates in MTEXT while editing
Uomoviso posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hi all, whenever I enter the MTEXT editing function, then type a letter on any given line of text, that line rotates to the world UCS. This makes typing almost impossible, as the overlapping text can't be read clearly. Any suggestions? I'm using AutoCAD 2013 for Mac and looking at my drawing with a rotated UCS.
