Showing results for tags 'rotate view'.
  1. Hi, I have leaned that there are 3 even 4 ways to rotate a view. For example, the view rotates with the viewport when viewrotateassoc is set to 1. The same is true using the align then rotate option of mvsetup. However there is a problem with the third method namely rotating the ucs and then applying PLAN command. I want to rotate the view 45 degree (by default it is 45 degree CCW). Hence I rotate the ucs 45 degree at the z-axis. However when PLAN is applied, the view has rotate -45 degree or 45 degree CW. Is there any reason for this or am I missing something? Regards, Nicolas MARIE. Regards, Nicolas
