Showing results for tags 'right click'.
    • right click ×
Found 4 results
  1. I just recently installed AutoCAD LT 2013 to my new computer with Windows 10. My right-click menu is not the edit options that I am used to and I can't figure out how to make it work again...when I right click it displays osnap settings. I have gone to my user preferences and right click customizati...
  2. Hi All, I am having a problem with AutoCAD 2011. Here's the problem step by step: 1. Select a line 2. Right click and select polyline 3. Select width Here's where the problem arises. ACAD used to prompt for a width now it runs the PEDIT command and asks me to select a line and then giv...
  3. guran
    Right click menus
    Hi! I am using AutoCAD 2012 and I like right click menus. If I use ctrl + right click, I get a menu with snap options, and if I use shift + right click, I get the same menu. Can anyone tell me how I can change one of these menus without the other is affected, and perhaps also how to get an alt...
  4. Hallo everybody, this is my first post here, I'm writing because I'm having a really frustrating experience with Autocad... I don't know why, I never had such a problem since the latest version, never realized there was this problem. When I right click on a selected object, I need the contextual me...
