Showing results for tags 'revit mep'.
    • revit mep ×
Found 6 results
  1. noob2009
    Revit Luminaire and two switch
    So I'm quite new with Revit and I still most of time I have no clue what I'm doing. But now I was wondering is it possible to add two switch to lighting? I haven't been able to do that, is it really possible?
  2. Hi Does anyone know how I can change the colour of only a small section of pipe? Thanks
  3. First I'll say that currently this is stemming from an HVAC drafter/ designer that just wants to put out some quality drawings in an efficient amount of time with not a lot of hassle - kind of like in AutoCAD. This is also coming from 20+ years CAD experience here so I am not talking out of my arse....
  4. Hi all, Could you please advise me an easy method for having a separate file for a particular system. e.g.: I had a Revit mechanical file contains hvac piping, ducting and steam piping for boilers, now I need only the steam system in a separate file. Could you please assist..? rgds, john
  5. Has anyone developed a way on Revit MEP 2013 to automatically select a pump from a loaded family based on a specific flow rate calculated? As opposed to manually selecting the pump size yourself? It would be much appreciated if anyone can shine any light on this subject! Alex
  6. We are a plumbing and HVAC contractor looking for a 3D piping package for coordination drawings and prefabrication in the future. We do not do sheetmetal. I have heard that Revit MEP is overkill for what we are doing but on the otherhand also heard its the future. We are leaning twords AutoCad MEP...
