Showing results for tags 'revision cloud'.
Revision cloud lisp with custom rotation of revision block on temporarily layer
fromMlm posted a topic in AutoLISP, Visual LISP & DCL
I found this nice revision cloud lisp made by Lee Mac: (defun c:rv ( / *error* ar bn cm el fn rv ) (setq bn "revlsp") ;; Rev Cloud Attributed Block (defun *error* ( msg ) (if cm (setvar 'cmdecho cm)) (if ar (setvar 'attreq ar)) (if (not (wcmatch (strcase msg... -
Would someone be able to create a dimension lisp that: Instead of numerical dimension, only shows a "?" And also puts a rev cloud around it as well I see when creating a new dimstyle, you can draw a frame around it. Didn't know if you could change that to a cloud automatically? I also need to...
- 8 replies
- question mark
- dimension
Hi there, I am making revision clouds on some record drawings. They come out all peachy, but when I save the file and reopen it, all of the wonderful little clouds change to jagged straight lines. Can anyone offer a solution? Thanks, Brian
Revision cloud in autocad 2002
pgw posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hi, Does someone know how I can make the revision cloud in Autocad 2002. Does it have the function? In which meny is it? What is the short command?
