Showing results for tags 'rename layouts'.
  1. ILoveMadoka
    Layout Rename - Fail
    I tried to modify this routine (to rename all Layout Tabs) (vl-load-com) (defun RenLay ( kword / n) (setq n 1) (vlax-for x (vla-get-Layouts (vla-get-ActiveDocument (vlax-get-acad-object))) (if (not (eq (strcase (vla-get-name x)) "MODEL")) (vla-put-Name x (strcat kword (itoa n))) ) (setq n (1+ n)) ) ) Which was found here: http://forums.augi.com/showthread.php?77060-Rename-Layout-tabs-on-multiple-dwg&highlight=rename layout To allow me to enter the desired name as part of the routine but I obviously don't know jack.. (vl-load-com) (defun C:RT5 (S1 / n) (setq S1 (getstring T "\nEnter New Layout Prefix:")) (setq n 1) (vlax-for x (vla-get-Layouts (vla-get-ActiveDocument (vlax-get-acad-object))) (if (not (eq (strcase (vla-get-name x)) "MODEL")) (vla-put-Name x (strcat S1 (itoa n))) ) (setq n (1+ n)) ) ) When I run the routine I just get *Cancel* I want to change the number(s) to start with a zero (01) but I'll "attempt" that next... If someone could explain "WHY" this doesn't work, I'd appreciate it..
