Showing results for tags 'rename block'.
    • rename block ×
  1. Hello, I have been a lurker on these parts for a while, now i need help with a problem of my own. (I use autocad mechanical 2013) I have a cad drawing which contains 1000's of blocks, each with its own part reference within. As we use autodesk Vault and cad's design centre in tandem both the...
  2. I have a 3D Autocad 2008 Mechanical drawing and I need to rename some blocks. The thing is I can use RENAME in order to change their name but when I do that, multiple blocks are renamed and I don't want that. I want to be able to rename each one of the block, individually. Is there any way...
