Showing results for tags 'remove material'.
    • remove material ×
  1. bengee54
    Trimming pipes
    hi, I've got a small problem; on the attached jpeg you will see a housing (shown in black) and a pipe inserted from underneath. how can i trim the material (of the inserted pipe) so that its flush with the hole in the bottom of the housing i.e. so nono is visible when looking through the hou...
