Showing results for tags 'reference parameters'.
    • reference parameters ×
  1. Hello all, I am creating a parametric drawing and I've run across a problem. AutoCad lets you define reference parameters, a measurement from a driven object, but when i try to use those reference parameters in a function, I get an error. I'm not even using the reference parameter to drive anot...
