Showing results for tags 'read only'.
    • read only ×
Found 4 results
  1. The problem we are having is drawings "automatically" switching to Read-Only when other users open the same drawing using the Sheet Set Manager. We've been using the Sheet Set Manager, in the same way, with the same amount of users, for years. The problem has only occurred recently. Here's th...
  2. We are in AutoCAD Civil 3D 2012. When we try to change something in a layers we created and it is telling us the layer is read only. The other day I shut the program down and reopened it and it started working. Today the same thing happened. What has caused this one layer to be read only? More impo...
  3. Hi, I've been given a dwg file to work with but it's read only so I can't save my work! How can I solve this? Is it possible to convert the file so I can save it?
  4. Hi everyone, how is it possible to find out any drawing is read only due to being opened by other one, without opening it?
