Showing results for tags 'raster image'.
How to correctly scale a raster image attached into an exiting file?
sinergy2020 posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hi I am trying to insert a raster image (aerial photo from google maps) in an existing topo map in .dwg format (am using autocad 2019 architecture) I use the usual procedure: https://www.cadtutor.net/tutorials/autocad/scaling-images.php The image gets scaled but can't see any longer t... -
I have a set of aerial images that I am hoping to use as a basemap for a paving project; about 20 images in total. Each is in TIFF format with an associated .tfw file. When using MAPIINSERT to place these images, only about six of them locate in the correct place. I can tell because I am placing...
- 3 replies
- .tiff
- mapiinsert
Raster Image looks out of place but isn't
hcostanzo posted a topic in AutoCAD Drawing Management & Output
Hello! I'm hoping someone knows a fix for this. I'm working on a large project, and I have 14000 feet of plan & profiles split into 500 ft sections, with a raster image as the background of all the plan views. The plan viewports are rotated 36 degrees using mvsetup. The problem is that when I...- 2 replies
- raster image
- plot
Hello, well i need your help for a college project.. i have a map from an abandoned camp in the suburbs of the city and i have to make a 'digitization' (maybe through Raster Image??!!) into AutoCAD (im working on Autocad 08) ... Can someone help me and write some kind "directions" on how to do this?...
- 4 replies
- insert jpeg
- insert
AutoCAD loads an image that doesn't exist anymore
jdavid10 posted a topic in AutoCAD Drawing Management & Output
In my drawing, I inserted a raster image file. I converted it into a block so I can modify it and I scaled it like this: I saved my drawing and I close AutoCAD, but when I open AutoCAD again the image shown on the drawing file is not the same image that I had inserted previously....- 1 reply
- non-existent image
- image problem
Raster Image later displays as the file name only
darrellk-1 posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Running AutoCAD 2004, XP Pro I have inserted our company logo into the title block as a Raster image. The logo is png, and I have tried retaining the path and not retaining the path with the same result. After saving this as a template, I reopen as new sheet to start a drawing and the logo is now...- 1 reply
- raster image
- autocad 2004
Raster Image moves in Paperspace when zooming/ Plotting
ljhignett posted a topic in AutoCAD Beginners' Area
Hi, As the title suggests i am having troubles plotting out of paper space. In my drawing i have an aerial photograph (inserted as a raster image) that has been scaled, rotated and shifted onto the relevant co-ordinate system. I have a locked viewport and when i zoom in or out the photo 'jumps'...- 4 replies
- raster image
- plotting issues
Hi, I have some issues with Raster Image lately when I wanted a scanned jpeg of 210 x 297 mm (a4 dimension) that I want to fit into a 180x220 mm rectangular box in Autocad. I have used Photoshop CS 3 to change the image size to 180x220. However when I insert the Raster Image files, some fi...
Plot problem - a COPY of raster seems to jump to front during plot, then disappears?!
Tallguy posted a topic in Map 3D
Hi CADTutors, this is an odd one. I'm plotting polylines, SHP data and a background raster. Until yesterday, all was well. Today, odd things are a-happenin'. This is a screenshot of the sort of thing I want to plot: The purple areas are CONNECTED and STYLED (in Display Manager) shp data,...- 1 reply
- raster image
- plot
Inserting Raster Image JPEG into AutoCAD...looks pixilated.
Pablo posted a topic in AutoCAD Drawing Management & Output
I'm trying to insert a JPEG of a SketchUP model as a raster image into paper space. The JPEG looks really tight and clear when viewing on its own but when I insert it into AutoCAD it looks pixilated and slightly distorted in places. Driving me crazy...any advice?
