Showing results for tags 'pull down menus'.
	Is it possible to make a pull down inside of a attributed block? For example: if I a have engineering code section of a title block and I want to be able to choose from a list of codes: ASME A17.1-2004 ASME A17.1-2007 ASME A17.1-2010 ASME A17.1-2012 Can I set up the block to let me do that?
- 3 replies
- block
 - attributed
	I am building a Object Data Tables and want to limit the input options into the fields. Specifically, I am looking for any way to limit human error/creativity while inserting values in ODT fields. For example: The ODT has a field titled Color. I want to limit the input options to blue, red or green for that field. Not yellow or purple or any other word. Ideally, I would like a pull-down menu, with the 3 color options, for the field value when I attach the OD to an object. Can pull down menus be used in the field value blank? Any ideas?
- 1 reply
- object data
 - fields
