Showing results for tags 'publishing issues'.
    • publishing issues ×
Found 5 results
  1. Hi, We're using AutoCAD LT 2013 and we simply want to plot some electrical drawings provided by one of our manufacturers in black and white only. When viewing the drawings on screen it shows all different colours used for different layers (I think), when we try plotting in black and white th...
  2. dboy413
    autocad 2015lt tabs
    Why can i not select multiple tabs to publish?? I use to be able to select all the tabs i wanted by hitting the shift key. Now i have to publish one at a time. Very frustrating! Thanks for any help!!
  3. Hello, I have recently introduced the Sheet Set Manager in my work flow. In my office they are not very keen on new and more efficient tools (they are French ) but I was left alone on a project and I implemented it with relative layout attributes such as titles, dates, revisions, etc. connected to...
  4. Hello, I'm using Autocad LT2012 and I have a problem with the "print to PDF" from the Sheet Set Manager. The layouts are all set to "publish to a plotter" with the Layout option (not Window, Extent, etc.). When I send the print to the plotter from the SSM, they print fine. If I send them to PDF,...
  5. I created a pagesetup to output to EPS files. Then i have our acrobat server convert them to PDFs. We typically get smaller files than using the DWG to PDF print driver that way. I can run a plot with the pagesetup and it works fine. However, if i use the same pagesetup on the same drawings usi...
