Showing results for tags 'property units'.
I am trying to dimension some of my house plans in inches to clarify some details for a subcontractor but am having some trouble. Attached is an example of what I am having difficulty with. I am running LDD AutoCAD 2002. I set the project and drawing to draw in Ft but when I use the Architectural dimensioning to get some ft and inches they do not match the length displayed in the properties. When I dimension using Decimal it shows it correctly unitless. As you can see in the attached the line is dimensioned as 40' 0" but the properties for the line indicates it as being 480 - apparently 480". How can I make the drawing units be feet so when I dimension in Architectural this particular drawing will show 480' 0" and the properties will also display a unitless 480. I have checked drawing settings, project settings, everything I can find to open and everything is set to Ft. I have found forum discussions about changing the scale, but that still isn't giving me a matching property length with the architectural dimension. I can of course just set a dimstyle to unitless and put the ' suffix, but I would like inches - everything has been drawn in respect to Ft. Any help would be greatly appreciated, thanks for everyone's time.
