Showing results for tags 'property sets'.
So Im getting a "too few Arguments" error message and after debugging I still cant seem to find which line is causing this error. The function of this lisp is supposed to select a register bock [attached below]: create a list for each block selected based on the cfm values in its [cfm] attribute. if...
- 16 replies
- attributes
- dynamic blocks
Creating Custom Tags That Group Identical Doors/Windows
MaxwellEdison posted a topic in Architecture & ADT
Ahoy hoy. Long time no see. Unfortunately I'm popping back in because I've recently been pushed into the hinterlands outside my experience. Namely, we're finally looking into the Scheduling tools in ACA and I've been tasked with learning the property set system well enough to make them match our...-
- schedule
- property sets
Synchronizing wall and door property sets - Need help!
BrianClarke posted a topic in AutoCAD General
I work for a healthcare facility which has several fire and smoke walls throughout. I've created a library of the custom walls that are commonly used. Under the property sets for the walls I have created a box where the fire rating can be inputed. Now, that I have the walls set up and I want t...-
- fire walls
- fire doors
