Showing results for tags 'properties window'.
Properties Palette error
lda2014 posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hi I am using AutoCAD 2014 'Architecture workspace' and I use the Properties palette a lot to change the attributes of linework to display linetypes/global thickness/scale etc. However, when I click on the model item (eg. polyline) the Properties palette doesn't change to inform me what the prop...- 5 replies
- properties manager
- properties
Problem with properties & Quick select tool!
hanirm posted a topic in AutoCAD Drawing Management & Output
I newly installed AutoCAD 2014 on my Win 7 operating system, problem is that when I want to use the quick select tool, it would be empty, with no items in it , even if I made selection to some items... I formatted my computer & reinstalled AutoCAD but unfortunately I still have the same problem! -
Still the same values in the Properties Window
Tereza posted a topic in AutoCAD Bugs, Error Messages & Quirks
Hello, when clicking on any object in AutoCAD 2014, I see always the same values in the Properties Window. No matter what I create or what I click on, I only see the same exact numbers which do not change at all. Have you ever had the same problem? Did you find a solution? Thank you very much for... -
This has been happening for a long time now, but today it's almost nonstop and driving me crazy. I have the Properties window docked on the left side of my screen. When I want to change the style of a piece of text, for instance, I'll select the text, hover over the Properties window, wait for i...
Is there a way to have the AutoCAD "Quick Properties" pop up functionality be transferred over after the dwg is converted into pdf or dwf? I want to avoid clutter in the dwg file but would like to have an ability for my field crew to either hover over or click the blocks or AutoCAD objects in th...
- 3 replies
- properties window
- dwg to pdf
- (and 3 more)
Autocad 2000 how to change visability of text in properties window?
neiloneil posted a topic in AutoCAD Bugs, Error Messages & Quirks
I know that when a listed property is greyed out it means it can not be altered from the properties window. I am struggling to even read the grey text as it is so feint. Is the darkness, and/or size of this text adjustable? It may be my eyes with the effects of age perhaps, but I remember...- 2 replies
- properties window
- greyed out
Hello im running AutoCAD 2010 as part of a Inventor Package and everything was working fine until i installed the Inventor 2011 ......(it was to try to sort something else out as the new features were introduced in 2011, but because of work policy were stuck using 2010......isn't work grand)...
- 2 replies
- properties
- autocad 2010
Properties and Design Center windows not showing
jskeeters posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
I can't see my properties and design center windows. The command line says the name when I click on the icon to open them but I can't see them anywhere on my desktop. If I clink again the command line says propertiesclose or adclose. When I saved and closed my last session they were open as I always...- 7 replies
- properties window
- lost properties
- (and 3 more)
