Showing results for tags 'projection surface'.
    • projection surface ×
  1. I wish to have outline/surface of those nonsolid 3D object convert or projection into 2D lines that can be use later. For solid object, its can be projecting the surface by FLATSHOT command But for nonsolid object, this command is doesn't work and showing nothing when I tried. PS. These...
