Showing results for tags 'print to scale'.
    • print to scale ×
  1. Hi all, i am new to AutoCad and as the subject has mentioned, i cant seem to find anyway to correct the size of the plan it appears on the paper. Played around with scales but my it does not work at all.. i Have to submit in a day's time and really need help asap!
  2. This is just a general question about annotative text, something I've noticed as we transition from 'each scale has its own text-dimension layer' to 'annotative'. I'm still a bit confused by the relationship between annotative scales in both DIMSTYLE and STYLE, and viewports, and actual plott...
  3. Hi I need help My client needs an a3 drawing I drew converted into a PDF so he can print the PDF off to the correct scale. I created the pdf in autocad 2012 to A3 size and a scale of 1:1. I emailed the PDF to my client who now says that the PDF is not to the correct scale when he prints it, I i...
