Showing results for tags 'print problem'.
ArchiCad into AutoCADLT 2015 not working of course, please help
bradw posted a topic in AutoCAD Drawing Management & Output
Hello, Architect on our project sends me ArchiCAD files in .dwg thinking they will work, and I am using Clipboard to Copy with base point, to move into my AutoCAD LT 2015 program file for the Client. Here, my layout 2 and 3 are pre-set to print to my Ricoh 2500 afico printer (11x17) and to my HP...- 2 replies
- print drivers
- autocad 2015 lt
DWG True View 2013 - trouble exporting to PDF or DWF
Jodym posted a topic in AutoCAD Drawing Management & Output
I am trying to create a pdf file from a dwg file, using DWG True View 2013. I am NOT a CAD user, so all of the terms are new to me. I read that sometimes it's better to convert the DWG to DWF first and then convert it to PDF. So, I tried 'export' to DWF after trying 'export' to PDF. In both cases...- 11 replies
- print problem
- export to pdf
Unable to print 2010 drawings in 2015 AutoCAD
amy vancho posted a topic in AutoCAD Drawing Management & Output
Once upon a time, in 2005, a basic map of our local communitty college was created as an AutoCAD drawing. The map included buildings, sidewalks and parking areas. As a student in 2010 I made copies of this map, did some surveying of planting beds and added the results to the 2005 on 2010 CAD. I have... -
Hello, This is my first drawing in autocad in many years. I actually managed to put the drawing together nicely in model space. i left the scale at 1:1 here. I then created a layout in paperspace. The page set up is also at 1:1. I created a view port and double clicked inside it, here I set...
Sheet Set Manager - Publish to PDF - Print slightly off
duccioa posted a topic in AutoCAD Drawing Management & Output
Hello, I'm using Autocad LT2012 and I have a problem with the "print to PDF" from the Sheet Set Manager. The layouts are all set to "publish to a plotter" with the Layout option (not Window, Extent, etc.). When I send the print to the plotter from the SSM, they print fine. If I send them to PDF,...- 4 replies
- publishing issues
- print problem
Hey All, first time post here, I have an issue that drives me insane. When I print a layout with a PDF or an image in the viewport, the print job size inflates to some ridiculous size that is much larger than my referenced PDF/bmp/jpeg. For example, today I tried to print an 11x17 color layout w...
Plot style table (pen assignments) not working
NoelStalker posted a topic in AutoCAD Drawing Management & Output
I've edited the plot style table in the past to do things such as change yellow to print black. I've also successfully used it to select monochrome to print B&W. Currently it's not working. I can select a different plot style, apply it and see it look correct in paperspace. However, when I previ...- 3 replies
- monochrome
- plot
Image shifts when printing in AutoCAD LT 2007
RussL posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Sometimes when I import an image (such as a TIFF or pdf) and draw over top of it, when I print the stuff that I've drawn shifts. It will look fine on the screen and in print preview but shifts when printed. Any ideas how to fix this? Thanks RussL- 2 replies
- print problem
