Showing results for tags 'print preview'.
    • print preview ×
Found 6 results
  1. I attached the plan I am having trouble with. It is named first_plan.dwg. I created some lines with the arc tool and joined them to represent the electrical wiring in the layer called electrical wiring. I changed the linetype to a dotted and dashed style but it won't display in the model space a...
  2. I attached the plan I am having trouble with. It is named first_plan.dwg. I created some lines with the arc tool and joined them to represent the electrical wiring in the layer called electrical wiring. I changed the linetype to a dotted and dashed style but it won't display in the model space a...
  3. sivapathasunderam
    color shows wrong
    color 255 shows color 253 how to change setting!!!
  4. Using ACAD 2008, I am having an odd problem where when I print preview/plot this drawing with a viewport the result is a blank page but when I remove the viewport it plots fine. Any ideas? Thanks, Jim.
  5. I have a strange problem with print/print preview. I create a 3d model in Autocad2012 for a mechanical assembly, then from the model I produce the 2d views I need. In addition to the 2d drawings I also create an Isometric DWF print. I then put all the 2d views together in 2d drawings, add the dwf...
  6. Hi guys, i have had to learn CAD this weekend to pass my degree, i had to create an alloy wheel front and side profile views, my problem is this - i have created the wheel in model space but when i goto layout 1 / paper space and insert my title block and border, then insert my viewpoint of...
