Showing results for tags 'press enter'.
"Unknown value "AC1027" encountered in drawing version. Invalid or incomplete DXF input -- drawing discarded. Press Enter to continue." (then the file disappears) MY workflow: I am opening up DXF files created by me with RASPLOT 2.5 and RASPLOT 3.0 (an Army Corp of Engineers Hyrdraulic model extraction program) I bring the DXFs into AutoCAD for better cleanup of the 2D graph it creates of flood profiles. OBSERVATIONS: Others in my office have opened the same engineering models in RASPLOT and been able to bring DXFs into AutoCAD 2011/2012 in with no problem. It had worked for me in the past, but I can't recall what happened to all of a sudden make it not work, EVER. My co-workers can work with the RASPLOT DXFs in Windows XP and Windows 7. ATTEMPTED SOLUTIONS: -I upgraded my RASPLOT version first from 2.5 to 3.0, then upgraded my AutoCAD2011 to 2012. No change. -If I create the DXF on my computer, then open it remotely from another computer's AutoCAD, I still get the same error message. (My only solution has been to create my DXF by remotely logging into another computer with RASPLOT then it will open in my computer's AutoCAD.) - I tried changing the .dxf file path to .dwg but that doesn't work. -One forum tried to explain opening it in Word and changing formatting? I followed it but that didn't change anything. ANY advice would be helpful, not much help from the RASPLOT side since they expect for the user to go through their cumbersome DXF Editor program. Thanks!
- 2 replies
- press enter
- invalid or incomplete
