Showing results for tags 'plotting problem'.
So when I print to pdf, all my line weights stay the same. I have them on different layers as per my schools CAD standards yet they dont change. To actually see a difference I have to open the layout box (when you right click layout 1 and go to plot) and change the sizes for different colors there....
Problem when plotting with transparency
belmartinelli posted a topic in AutoCAD Drawing Management & Output
Hi people, I am having a problem when plotting .PLT files. Just wondering if someone had the same problem, and a solution for it. I am using AutoCAD LT 2012. When I plot with transparency box ticked, the result file is displaced, and doesn't respect the defined area. I attached examples, the sam...- 4 replies
- plt
- plotting problem
