Showing results for tags 'plotting dwg to pdf.pc3'.
Plotted PDFs: Text turning into little white boxes
TheyCallMeJohn posted a topic in AutoCAD Drawing Management & Output
Hello Forum Friends, So I have a problem, new to me but hopefully someone has run into this and generated a solution. Our company plotted some PDFs using Publish, DWG to PDF and all the text came out fine but when our customer views the text in Bluebeam some of it is replaced by little white sq...- 4 replies
- plotting issues
- plotting dwg to pdf.pc3
- (and 2 more)
Converting CAD Files to PDF with proper Lineweights
landgroup posted a topic in AutoCAD Drawing Management & Output
I'm having problems plotting to PDF's and maintaining the line weights etc.. that I get when I print to my plotter. It seems like Adobe Acrobat Pro 9 converts based on the color of my pens.... the lighter color value i.e. yellow, the lighter the grey tone. white is darkest. It ignores my lineweig...- 3 replies
ACAD 2011 /DWG to PDF.pc3/ Can't get 2D Arcs to Plot as Hidden
zflowrpowr posted a topic in AutoCAD Drawing Management & Output
After 2 days of trying to crack this I can use some help please! I've just upgraded to 2011 (which may or may not be the culprit) I use a CTB to Plot my 2D Plan-sets and I'm having problems getting several arcs in the drawing to plotas hidden lines. Lines and P-Lines on the same layer print just fin...
